Let me bust your bubble as gently as possible; It ain't gonna work!
In my 30+ years of experience, I have seen large glass Transmitting (3-500Zs and, 4-1000) Tubes used in mobile service and, the owner/users end up throwing away a bunch of money and they are never satisfied with the outcome.
For whatever reason, the high wattage that they put out is as weak a water and, a transistor amplifier will cut right through 3-500Z/4-1000 carrier. I know, I tried it years ago on the Shoot-Out line.
Look at the "Mechanics" of making that thing run in the mobile; Filament current of 90 amps at 5.0 volts, takes a lot of BIG resistors to drop the 13.6 volts down to 5.0 volts to light the tubes. 3-500Z tubes should be run with a center-tapped AC filament transformer with the CT being the cathode return/bias circuit. How are you going to do that properly? With a big inverter that imposes an audio whine on the "AC" output.
Are you really going to try to generate the B+ needed (3000 volts at 3 amps minimum?) via a stack of 3 phased alternators and transformers on your Stroker 318 engine or, do you have a 454 cu. in motor?
However, there is nothing wrong with Champagne Dreams on a Beer budget!
YMMV.
One more thing, "If you need more than one tube to get the power output that you want, you need a bigger tube". Sell the 5-Tuber and think about a single "Steel Toob" amplifier
