Guys don't leave in this antenna nightmare! The more I read the dumber I get??
Your not actually getting dumber, you are just realizing how much you don't know.
This antenna theory is hard on my brainDx. Is the main purpose for all this head scratching .... This antenna will be mounted at the water (saltwater)line during use at 10-20 feet....looking to get a lower radiation pattern to work Dx from the beach.
Here is a link to a thread that is a sticky up in the HAM antenna section, it talks about take off angles. It is a good read.
The Myth Surrounding Antenna Take Off Angles
Making the antenna electrically a 3/4 wave for resonance and 5/8 wave for the radiation pattern? Is think ? Is this what is being attempted? I understand past .64 wave antenna pattern break up into many lobes and nulls....I want as low a radiation take off angle with the majority of the radiation in that low angle Lobe? Correct?
This is how it is done. Think of it like a 4 foot car antenna, it has a coil/matching network to keep it resonant as a 1/4 wave antenna, yet the antenna is much shorter than 1/4 wavelength. The actual length of the antenna and not the electrical length at a frequency determines the radiation pattern.
Radials....mine measure 102 inches. Would a be better to add another radial ring below the ones currently on the antenna...I have the parts and tubing.(ended up with 2 of these antennas?). Would this be the same as folks adding 120 wire radials to some verticals?
Ground mounted verticals need all of those radials. As the actual ground (as in the earth) makes a very inefficient ground plane, those radials are used to increase the conductivity of that ground.
In your case, with raised radials above a few feet off of the ground, it will make far less difference. You can add them, and they shouldn't hurt anything, but I don't think you will get much of a benefit from them either. That being said, if I had them I would likely put them up anyway. They will increase the wind drag load on your antenna, if you see that as a drawback. As another drawback you may have to adjust the radial length some as the radials do react with each other when it comes to tuning, and you have more then the original design specs.
I thought the mast would be the other half such as a dipole. Some models I have. Found on the web show the mast and feedline radiating? I have thought about adding wire radials around the mast laying on the ground but reading these must be a certain wavelength and would not be worth all the tuning....I can't get a simple antenna to tune so adding issues is the wrong way to go.![]()
The other half of the antenna in your case are the radials. One thing they are supposed to do is help decouple the mast/wire below them from the antenna.
You will note with a dipole that both sides are tuned lengths. A mast is not, I suppose you could try and tune the length of the feed line with a choke at an appropriate point. Also, the radiation from the mast/feed line in most setups works counter to the radiation from the antenna.
ghutch, did you read the instruction DB linked to for you?
My linked instructions?
Did you mean:
ghutch, here is a instruction sheet that was reportedly produced by the premiere installer of antennas, world wide, and beyond, Master Chief and he tells us so in the first sentence.
Odd, when I quoted it it changes the name on the attachment... It should have said "Master Chief's Instruction on the V58.pdf", maybe it will update itself.
The DB
