Replacing the tired 99v with new 98vhp in 2008 Kenworth. New radio came tuned & ready to go with 50amp glass fuse @ radio end with the quick connect. Do I need another 50a fuse @ battery connection? Is it ok to run hot from the connection under hood?(2-6 gauge cables already connected to this) Or should I go direct from battery. How about negative cable-same question. I've done quite a few radios in past-still consider myself a rookie when I have alot of $$$ invested. Just reading thru this forum I can see there's alot of know-how I would like to learn. Thanks to all for any input!
