Why buy? Build your dipole (not "diapole") and save at least half over what a commercially-built one would cost (plus the shipping).
Lets see....uh....thats what I want to do at this time!
well mouning it hoizonally normally takes all that out [no gaureentee] heres something 2 think about if ya talk to local using verticle polarized antennas you,ll either lose them or most likely notice a drop on signal both tx/and rx.Robb,
I bought one of those a ways back for my CB. As you know from last year, and currently, I am still experiencing 3 db of noise level at night on my base. Lately, I have noticed, that by morning, the db level of floor noise is gone. Not even 1 db. Strange eh? Then a thought occurred to me. Maybe it is a bad halide street lamp buzzing as soon as dusk approaches, and at dawn, the noise is gone.
Anyways, in which brings me to something I read last year and correct me if I'm wrong, but by mounting a dip pole antenna horizontally, one can then avoid the vertically polarized interference or noise that our vertically mounted base antennas are picking up. Same as in using a beam antenna horizontally.
So I am also wanting to set mine up as soon as it gets warmer out.
Interesting post Robb.
For a flat SWR you will have to set the wires at a 120° vee, then tune for flat.
- If you cut or extend the wire to tune for flat at a lesser or greater vee angle you will actually be increasing the rectance and losing performance. Not a big loss but better to cut it to the right length and live with up to a 1.5:1 SWR, depending on the vee angle.
At a 90° vee (37ohms, 1.5:1 SWR) you'll have equal energy in both the vertical & horizontal polarizations in all directions ('spherical pattern'?) unless you're after more broadside horizontal performance.
Not necessarily true. The height of the antenna and distance from metallic objects in the near field are at least as important as the angle. The ground composition and resistance figure prominently in the mix also. Perfectly horizontal dipoles work just as well as the variant known as the "inverted vee". No two antenna installations are going to be exactly the same. You have to put it up and try it out
Dipoles do not have to be horizontal.
Due to many CB users having mobiles, makes end fed base antennas common.
The first dipole antenna I made was a copper pipe one. It was vertical.
