Not too long ago, MFJ started marketing the MFJ-1790 10 meter vertical as a quick-install antenna that is perfect for portable operations. I contacted MFJ about obtaining one for an article and they sent me one to try out.
Here's everything that comes in the bag, laid out on the ground:
Here's a full length picture. The longest aluminum tubing are about 5 feet long, which doesn't make this antenna the smallest portable antenna available, but at least it's manageable.
Assembly of this antenna is pretty straight forward. This is the hub that attaches to the mast and supports both the vertical and horizontal elements.
Simply attach both the horizontal tubing and then the bottom section of vertical tubing. The ground plane radials are securing with the supplied hose clamps and the vertical is secured with a small machine screw.
Attach the top section of vertical tubing and then measure the overall length to set it at 11 feet, which is the length indicated by the manual.
Mount the antenna at least 3 feet off the ground to test for resonance:
I initially hooked up the MFJ Analyzer and couldn't find any frequency where the antenna would work, so I knew something was wrong. After taking the antenna down and unscrewing the hub from its base, I found this:
The MFJ-1790 claims to be an off-center fed vertical. As you can see, the matching section is inside the hub. The antenna I was shipped had the center conductor broken off during assembly. I quick solder job fixed the problem, but when I put it back together, the tight assembly made it easy to understand how something like this could happen.
Now that I had the antenna assembled properly, I got it back on the air and found the frequency where the antenna was initially happy:
Seeing that it was much too long, I shortened the top radiator and was ready to go within a few minutes:
I hooked up the MFJ-9410 10 meter SSB transceiver and was ready for some back yard QRP fun!
A couple of notes about this antenna: The tubing is pretty thin walled stuff and will get damaged easily if the antenna comes down and falls on a radial. In fact, the radials can be bent pretty easily right at the hub. The antenna is easy to install, but you should check out the matching section inside the hub before you take it to the field to play with. I wouldn't claim that the antenna works any better or worse than any other antenna of similar design, except that it's definitely not intended for permanent install due to the thin tubing. The antenna retails for about $70 and would be a good choice for working 10 meters at a campground, backyard or similar location where space is a premium.
