A Good question..
CB can be costly depending on the radio(s) used..
Then the adding of a good amp..
Then a good antenna set up ( be it base or mobile )
and suddenly it turns into a rather costly set up (even for CB )
However..
I think ham radio typically is more expensive..
Depending what you are doing..can be way more expensive.
At least though(despite some of the extremely expensive HF radios)
one can indeed gets lots of bang out of their ham gear..
Getting basically several radios in a single radio
( like 706 MKIIG or IC 7000 )
If one wants to push to the extreme end of CB or HAM radio..
Then Obviously Ham radio will be far more expensive..
( i am well into 10's of thousands and do not as yet have a antenna set up i like/want )
However..
