Hi,
Thanks Gentlemen!
I am going to make a notebook and take notes on all the info given and from the vids.
Helps to see everything in one place!
I wanted to use the dummy load to set the radio as I could then work on the bench....
Instead of the front seat of my truck!
As I understand it now, I"m just going to go in and bring the dead key from the factory 4 to a 2 amp read and then run the amp.
I asked about modulaton as there is a pot for that and is usually turned up (my understanding) on a "tune and peak"!
However, seeing that I will also be running a power mike and the amp, I'm thinking of leaving it alone and just do the dead key and get out.
Then I can check the SWR with the actual antenna and hopefully be good???
Thanks Gentlemen!
