Just wondering, is there any budget cheap AM radios on Amazon that can pickup CB 11 meter frequencies?
cheers
cheers
probably a stupid question, but will a class C amp work on SSB?
Not really.probably a stupid question, but will a class C amp work on SSB?
if you had an amplifier with switchable biasing you could switch it over to A/B biasing for sideband and switch it over to class C biasing for a.m. if you chose tois there any mode to make it work?
not sure if an Xforce is switchable or notif you had an amplifier with switchable biasing you could switch it over to A/B biasing for sideband and switch it over to class C biasing for a.m. if you chose to
http://www.worldwidedx.com/threads/x-force-amp-is-finished.138726/not sure if an Xforce is switchable or not
yep I went there and got the info I needed, again thanks.
There are people in this forum that could reengineer and rebuild it for you but the price to rebuild it from scratch would Probably exceed the value of the amplifier.rabbiporkchop thanks for your help I really appreciate it
ok don't the SSB switch on the front change it from c to a/b?There are people in this forum that could reengineer and rebuild it for you but the price to rebuild it from scratch would Probably exceed the value of the amplifier.
