Jeremy: The issue is this. Think about the "Air Foam" center of the 400 or 400 Flex, as you turn the coil the foam will tend to collapse. This allows the center conductor to "migrate" towards the outside of the cable as the coil is made. This will decrease the amount of dielectric material between the outer shield and center conductor. This in mind reduces the power level of the cable, plus the length of the coil actually increases as the "migration" of center conductor occurs.
There are some whom will tell you the "solid" dielectric material tends to reduce this effect, and makes a better choice for winding a long lasting "ugly" balun or "Air Choke"
I tend to agree to a point, much depends on the cable manufactures specs on the minimum "Bending Radius" allowed before degradation of the cable properties begins.
All the Best
Gary
PS: LMR400 or Flex... Bend Radius: repeated inches 4.0
So as you can see the 5 turns on 4.5 inches coil required to correctly wind the "choke" is "barely" with-in specs before the cable begins to degrade> (?)
All the Best
Gary
