Shadetree Mechanic
Delaware Base Station 808
The Autek wm1 is an awesome meter, no longer made, they pop up on ebay from time to time. I have purchased 3 of them over the years, all used. Cost way less than a bird and just as accurate.
Yeouch! Okay, i need a PEP meter, but one that i can not spend as much as a bird. My radio is still in the shop.BIRD Model #4410-A Wattmeter and #4410-4 Element
Down is AMThere’s no idiot diagram for this thing. The right switch is 4 AM or single sideband the middle switch for the preamp?View attachment 63951
Preamp on left.There’s no idiot diagram for this thing. The right switch is 4 AM or single sideband the middle switch for the preamp?View attachment 63951
Just follow the horizontal white line to the end, that is the On/Off rocker switch for the amp only. The red light will come on.There’s no idiot diagram for this thing. The right switch is 4 AM or single sideband the middle switch for the preamp?View attachment 63951
He has purchased a KL 203P.
Sorry I thought he said he needed a meter for PEP reading. Dosy works for that and doesn't break the bank.He has purchased a KL 203P.
I couldn’t find those specific instructions in English and Perhaps it is stated in Italian.Just follow the horizontal white line to the end, that is the On/Off rocker switch for the amp only. The red light will come on.
The rocker switch on the left is the preamp. The preamp can be used with the amp off as indicated in the instruction sheet. When the preamp is on and the amp is off, the green light will be on. When the preamp and amp are ON, the light will be yellow.
Got it?
Ye, that site has a lot of meters. I want one that can remain in line.
Self-explanatory. The end of the horizontal white line is above the center rocker switch. That is the On / Off for the amp.There’s no idiot diagram for this thing. The right switch is 4 AM or single sideband the middle switch for the preamp?View attachment 63951
yeah, I guess that’s why I posted hereSelf-explanatory. The end of the horizontal white line is above the center rocker switch. That is the On / Off for the amp.
Yeah I have 3 dosy meters and leave them in line. I have the one with the antenna switch with 4 positions and then bought the TFC-3001 because it reads frequency and then found out it didn't read SSB frequency so I bought the TFC-3001-S because I wanted to be able to check SSB radios. Dosy is OK for the average radio operator but I wouldn't want to get into radio repair with that grade of equipment. My first one was checked with a local shop and calibrated with his Bird Meter and has been sufficient for my use. All 3 of mine are in-line at different locations as I type and surprising the TFC-3001-S frequency reading agrees with all my Good Talking radios. Hope that helps you.Ye, that site has a lot of meters. I want one that can remain in line.
