Another Noise question
QRN said:
Use a capacitor of about 0.01 microfarads and install it directly across the wires going to the fan motor as close to the fan motor as you can. Just strip a bit of insulation off each lead and solder each leg of the capacitor to a wire. Polarity does not matter. Be sure to tape the connection well after. That should reduce the noise considerably.
can i try this on the injectors of a mack diesel engine to stop the rf noise? thanks
