Another PC122XL TX Problem
Not to be captain oblivious here but...
Make sure you have the right Mic wire to the right spot...
Last minute detail - kinda' thing.
Regards!
Andy I was thinking the same thing this afternoon. If the ground and audio were somehow swapped I was thinking it would have the same effect. I think.
Ground thru a 600 ohm might - because speaker is done differently - what normally would use 1 - 4 on the mic socket is toggled internally thru a diode on the main board (that D38 and CB PA switch in CB) - but if the mic wires to the radio were reversed ... hmmm...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
