Antenna Analyzer Options?
The Jerk
647
66
38
Reading, PA
Other than the MFJ-259B, what other options in the lines of antenna analyzers are there?
I have been trying to buy a used one, and every time I'm too little too late...so, I decided to buy new. Looking for one that provides similar outputs as the 259B...and less than $300 if possible.
What options are there??
I'd show you a real cable/antenna analyzer, but we gotta stay in fisher-price land for $300. This is probably too much:
lp100
How portable is it? Depends on which display type/style you want to use. If you want the all-purpose computer display, just how portable is your computer? If you're satisfied with the display on the meter it's self, you only have to supply operating power.
Because of the graphs it can do I can certainly see where this 'vectoring watt meter' could come in handy if you are evaluating antenna systems. If it's just to do a 'one-time' antenna tune, maybe it isn't as economically feasible? Different strokes/different folks.
Unless you're a kit builder, I think if price is your determining factor, stick with the MFJ analyzer. If you really need/want the other abilities, go with the 'LP-100'. Now if it would hit the 400 - 600 Mhz range....
I like the Autek VA1, but it is a lot of work to scan a bandwidth and that is the only real way to tell what is going on with your antenna. The LP minivna is very nice, and will take a full scan for bandwidth if you enter in the correct perameters and will do it in a second, but the thing comes with little or no instructions, so unless you have much understanding it will be tough, and you need a lap-top computer if you want to even consider being portable.
Bob85 has one and is the man to talk to. I might have already said something off base, but I do like my VA1 Vector analyzer and it works with a little study and understanding.
I'd recommend springing for the 269 if you do go the MFJ route, it's nice to have the 440 in it even if it has more limited features for that band.
Your budget won't permit it, but the only thing that would be better is an actual VNA, computer based analyzer that sweeps and also plots out in easy to read charts, the characteristics of antennas.
I use my 269 a lot more than I thought I would when I bought it.
I think a lot of those are way more than I really need at this point. I was looking at the Palstar ZM30 (similar to the 259B) also...I like the fact these are self contained and portable, and don't require a computer. I don't think I would ever get into the depth some of those analyzers provide...and if I would, the one I buy now would be outdated by then...
The $300 thing was just a target...not set in stone.
I was thinking of getting a LP-1000. Tell me more bout this thing.
Sorry to steal the thread but I am just for this quick question.
Thanks,
AP
It's the LP-100 from Telepost Inc. A fantastic piece of gear, but you need it to be attached to a computer for the vector analyzer functions.
lp100
One other reason I was looking at options to the 259B was because some of the reviews show them to be problematic if that makes sense...they are reported to quit working for no reason, need calibrated quite often, and are reported to be poor construction.
I was looking at the Palstar?
Just something to think about, not an excuse or an endorsement for MFJ, please don't take it that way.
None of the antenna analyzers that are commonly available for 'hobby' use are going to be lab grade devices accurate to greater than 27 decimal places. Typically, a one decimal place increase in accuracy means at least one additional zero added to the back end of it's price. And unless that device has a 'live-in' elf to watch over it, it will never retain it's accuracy for ever (a year, if you're lucky). If there is anything that has a mechanical movement, it will always loose accuracy over time, along with the completely 'solid state' thingys because of normal use. Most analyzers are of the "yardstick" type, not a "micrometer" type.
Needless to say, quality control with MFJ isn't exactly the absolute most best of the industry. It is also not the worst, believe it or not. The good part about that is that they will make up for any goofs (unfortunately, they are pretty good about that, lots of experience :)).
All of that depends on how much care you take with that device's use. the one I have now is not the first one I've had. Most problems (all of them really) have been my fault. As in don't drop the stupid @#$ thing! Put it away when you're through, don't leave it out in the rain, or just leave the @#$ thing turned on and forget it. None of that contributes to accuracy or longevity. (That's MY problem! I've been left out in the weather too many times. Good excuse, isn't it??)
Why do you hear about more problems with MFJ's analyzers than any of the others? One reason is that there's a whole lot more of them around. Like Fords?
And considering how most of us use them, and for what, they really aren't that bad. And like everything else, the 'best' one for you is governed by personal preference/cost. So get the one you think suits you best. Nothing wrong with 'bells-n-whistles', but will you ever use all of them? Really?
I have a 259B that I'm sending in to be re-calibrated. I've used it alot and the OHM's resistance is off. Thinking of buying another one as well. Mine gets alot of use and I'm very careful with it.
