Got back to working on the antenna today and got the ground radials attached and the matching circuit hooked up and results were good .
Channel 1 1.4:1
Channel 20 1.3:1
Channel 40 1.2:1
Putting in about 22 watts.
Did not have to use the coax capacitor, actually results with it on were really poor. Tap point on the coil was typical, about 2 turns down. First contact was about 50 miles north of me with the feed point of the antenna about 6ft. off the ground .
Next job is to get it on the house and about 35ft. up.
More to come.
John
Hey John,
I'm coming to the party late on this one (you snuck this by me while I was tied up at Talladega), but good stuff! I was wondering what you were going to do with this that you needed an LC circuit at the base... But right, you shouldn't need a capacitor across this one. And your coil looks better than the one I made with the runny epoxy!
I look forward to seeing more pics and hearing how this performs when you have it up in the air.
Rick
