G-450A YAESU G450A 10 SQ FT ROTOR (rlham.com)
You get what you pay for...$150 every 4-5 years for (Light Duty/TV) rotor with no brake. Constantly requiring calibration, rocks back and forth in anything above a 10-mph wind (causes signal distortion). Just made zero since to me anymore.
I have a $160, NEW Winegard 70 element antenna (15+ft. boom) to receive stations 35+ miles away. These stations, some of which are LP-DTV require every DB of signal to receive. The power reduction of the standard DTV channels since the changeover from analog makes it difficult from that distance to hold and lock the signal.
I got tired of dealing with junk rotors on the tower.
I installed 25 ft. Rohn 25G, with about 10ft of mast, mounted the new antenna at top (maybe 30+ feet). I also added a mast mounted pre-amp. I used the Yaesu rotor mounted on plate about 2 feet below top of tower. I get 60+ stations (about 45+ usable) (removing the religious and shopping stations
I finally realized the futility of trying to "do it" on the cheap.
I recommend this rotor for ANY beam antenna 3 element and larger (HF/CB type) or any TV antenna with a boom (8ft.) or panel style larger than 2-3 ft across.
(Any antenna w 2.5 Sq. ft or larger wind load)
I will be replacing the 11-year-old 50-inch SONY XBR (atsc1.0 tuner) soon now that the locals have went to
atsc 3.0 broadcasting (TRUE UHD).
ATSC 3.0: Everything You Need to Know About Broadcast TV's Next Big Thing | Digital Trends
Good luck with those "cheap rotors" made in CHINA (I think one Chinese company makes every brand now... (RCA/Channel Master/Philips etc.)
All the Best
Gary
