The problem with resonance is that an antenna is only resonant on one frequency. It can maybe be sort of resonant on a range of frequencies, but very seldom over a wide range. By definition, resonance is the absence of reactances. Even so, when at resonance, an antenna's input impedance is almost never very close to what the average transmitter wants to see, about 50 ohms, without some sort of impedance matching being done. That impedance matching for a single band antenna is usually some fixed device. For most multi-band antennas, there's an impedance matching device and then the lengths, or positioning of 'traps', is selected so that that matching device can be used for all of the covered bands. The measured lengths are not what would normally be called resonant, but combined with the matching device and trap, the resulting length would exhibit no reactances making the thing resonant. One example of such a thingy is the tuner and whip combination produced by 'SGC', where the tuner is at the base of the antenna. What 'SGC' doesn't advertise is that the further away from the frequency that whip would normally be resonant on, the worse the efficiency of the thingy is. Where the whip is something close to one of the 'typical' lengths thought resonant (1/4, 1/2, 5/8 wave), it does work fairly well. On bands where the whip is extremely electrically short, you can shout further than the resulting signal will go (an exaggeration, but not much of one).
The biggest draw back for tuners is the feed line between tuner and antenna. If that feed line has much loss, or is subject to deterioration because of the resulting voltages from the SWR, it ain't the best situation in the world. If you don't have to worry about the feed line being destroyed by high SWR, then it can work very well indeed, in terms of radiated signal getting to where you want it because of non-resonant antenna lengths. That doesn't mean that always using a tuner is the best possible means of doing things, but it does mean that in certain circumstances it will mean making an inappropriate antenna usable. Which is basically the point of this thread. It doesn't say anything about how appropriate any particular length of antenna is, some are just not going to be very good (usually too short).
