You at one time sent me several AP models by email, but the PC I was using then crashwd and my email account has been purged either by me or my provider.
I don't have them anymore...
I wondered whether the center frequency could be slid up ordown as with the coventional vertical monopole by this device, or would it require dimensional adjustments to the whole antenna...My modeling has demonstrated this. Making the vertical element length to the cap hat shorter and lengthening the cap hat elements to compensate will lower the R value.
The DB
I may try to do a 2m version to play with. Would anyone care to come up with comparable dimensions?
No analyser or bird at this location Eddie so I checked swr bandwidth with my kenwood sw200a meter,
this is where it first reaches 2:1 its still 2:1 a little wider than noted below,
using more than 200ft of RG213 from meter to astroplane with the coupler screwed directly to the radio 2:1 bandwidth is 24.870 - 27.950,
Minimum vswr is on 26.460 so its way lower than id like it to be,
I think unless somebody can show otherwise that a 1/2wave mast above the isolator causes the least mast current below the hoop and least effect on vswr.
DB, what you claim maybe true, but I'm trying to keep my model true to the specs until it looks right. If Homer builds another home-brew of this A/P maybe he can incorporate tuning the radiator, top hat, and the two radials into his design...and check your idea out.
I would use 1/4" tubing, 1/8" cap hat rods. Centered on 145 Mhz.
Would anyone care to come up with comparable dimensions? Could this be tried against the 11 meter dimensions - 11m dimensions X 0.18604651= 2m dimensions centered around 145 Mhz?
I have no scientific formula as I am a man of simplicity.Which formular do you use to switch frequencys/length, Homer? A friend build a 2 m version of the AP years ago, when i remember correct with good performance too.
I mean he used thin 1/4" cooper pipe what he soldered.
Im very interested in building a 20m version of the AP with an 80 ft mast as base. Should be very funny dx-ing!
Victor
