You need a new drive.
Yeah...but how do I know which is compatible with this model pc?
Does she want to save her pictures and other data from the HDD? You could probably connect the hard drive on a running pc as a secondary and copy to a DVD or USB drive
I mentioned it earlier.
3.5 inch SATA
Well the hard drive now is a hitachi hds721075cla332
3.5" SATA-300
You can find the hitachi hds721075cla332 on google shopping search for $55 and up but it was me I would get a larger drive
Maybe maybe not, up to him to decide that. I have not found anything that I used on a daily basis when I used WinDOZE that I cant get on Linux. I can also get just about any WinDOZE app to run under Linux as well Via wine or VM.Respectfully, he doesn't need an operating system.
He does need a hard drive.
Linux just doesn't have the programs that he was probably running and still needs.
Replace everything in the box and eventually you will fix the problem.:thumbdown: Now that we have identified the correct drive that is causing the errors you can narrow your focus.
One last thing you can try before spending any money is to format the drive and reinstall the OS with your recovery disks.
