old 813 homebrew Amp
If you look at this photo you can see the diodes on top of the caps. You will also see two MOT as the power source. This was not the images I saw before I just accidentally found this just now.
Another accidental find where we have components stacked on top of caps.4-1000A Homebrew Amplifier
The first link shows voltage equalizing resistors across the caps. The second picture shows a separate plexiglass board with the rectifiers mounted above the filter caps. The rectifier board consists of several series diodes with a resistor for voltage equalizing and a disc capacitor for surge suppression across each diode.
As for microwave ovens not using electrolytics, 339 is right. Both you and he were talking about the HV filter. In a microwave oven the typical filter cap is only 1 microfarad at best and is not necessarily electrolytic. The filters in a microwave oven are very poor and the power supply is dirty.
