Anytone at-5555n II (version 2)
I didn't have mine open, but Timmy posted a pic in this thread that I looked at. I sort of recalled that the part designation in the PA were descending, or I would have assumed the same as you did.
Nice. BTW, in the Q6Pro, the pre driver and one of the finals are labeled "Q101" on the silkscreen. LOL
I had ordered an AT-5555nii and I forgot to order the program cable. I have other program cables, and I am wondering if they might work. I have a ss7900v turbo program cable, an Antyone d578uv program cable. Does anyone know if either of these cables will work on the at-5555nii? The reason I am asking now is if they do not, I will order one from amazon ASAP. Merry Christmas and may God bless all on this forum. Thank you. From this old man to all.
Reactions: Pez and FlyBoy50
Yes, your cables will work fine!
Some are saying that you take off the the cover of the radio and there is a white wire looped that you cut and next to that wire is a jumper pin that you move that pin over Then turn on your radio. Remember to not have any power on until your done. I do not know for sure if this is right but that is what I found on YouTube. My radio should arrive probably Wednesday or Thursday. Please let us know on this forum if this is what you found . I hope this helps I ordered the program cable and it will not be here till the 23rd. Merry Christmas and May God Bless everyone.
That is exactly right. You unhook power, snip white wire, move jumper to the adjacent pins, and then repower radio.
One other thing I found is if this is not on the board they say while the radio is off press and hold the FUNCTION button with the EMG while turning on the radio. You will see on the display band 1 rotate the channel till you see band 2. They say hold the function button for several seconds till it it shows the band you choose. Then turn the radio off then back on You should now have it ready to use Choose band 2 for all frequencies to be used including 12–11–10 meter bands frequencies. This is all the info I have found on the net. Once again I hope this helps. Let us know if this works If my radio was delivered I would had tried this myself I guess I will know either by you and others or when my radio comes and then I try it myself.
I just got your post about this mod is on the board and you cut the white wire and move the jumper pin over. Thank you and disregard my last post since it is not the one that works. Thank you Merry Christmas and God Bless you all.
Reactions: BC Coyote
  • @ Geoexplorer69:
  • @ Geoexplorer69:
