Update:
Second e mail sent.
Got a reply from Quxaing today.
Short, to the point.
"Sorry not, the hardware is different."
So that's the word from the guys building them.
Thanks for this info. I just got a 6666 so I will be looking at this again.the NPC / swing mod will work for the anytone quad 6, Stryker 955, Stryker 655, the anytone quad 5 and quad 5 end, it's all the same circuit. Cathode of 1N4148 signal diode to center pin of the a.m. regulator. I add a 47 ohm 2 watt resistor for slightly more peak, you can use up to a hundred ohm or more if you want to tighten the peak a bit. Solder the resistor to the anode and the other end of the resistor as pictured to the rear most solder joint which is the positive pin of a capacitor. Do not short the two or you will fry the PA stage. Heat shrink it and enjoy.
I have to ask since I know you now own one. Did you mod yours?Here is the picture from Tim in case anyone missed it. This info is on page seven.
Not yet. I thought about doing it to run a 4 pill. I will have to see if I have the right diode.I have to ask since I know you now own one. Did you mod yours?
I did not do the NPC-RC or RWB mod on my AT-6666 (plenty of swing IMHO) which uses IRF520's in a 1x1x2 configuration. I
