prolly stuck with it.prolly end up in pieces in the junk/burn pile where it will polute the friendly liberal skysMaybe so. If that’s the case, how hard is it gonna be to convince where you got it and get them to swap it out?
No other objects at least in 11m radius.
What does 102" have to do with an A99? I've had 3 A99s over the years and each was made of 3 sections just under 6' (72) each.
It sounds like there are some quality control issues behind the newer ones. If anyone can elaborate on that, I'd appreciate hearing about it.
Thanks.
it 1 of those pos items that after some wasted effort its toss n get something else. i usually can achive low swr in installs but this turkey is not cooperating.a friend about 35 miles from me had same thing happen.he got another a 99 n same crap as mine. im thinkin qc issuesReplacing the top section with a cut-down 102” whip, that is what I was referring to. Ice will break that tiny fiberglass end section, had it happen before so I replaced it with a cut down 102.
And to go against the grain here, I did achieve a “correct” SWR by trimming that tip. However, my A99 didn’t have a tuning issue to start with, I mentioned it only as a “try it for the lulz”.
all new coax. no switches.friend got hit same time as me got another a 99 as we both were happy with our old a 99's but his matches mine now n we both are thinkin junk junk junkIs the new antenna actually shorter than the old antenna? If it's the same length than that isn't the issue. Do you have an antenna analyzer?
As Sp5it mentioned if you can't get a good SWR reading up or down from the CB band than the issue may be something else.
For example - the issue with the shorter Imax antennas - we all were seeing lower SWR above the CB band and could get a 1.1 or lower at higher frequencies.
I'd suggest picking up a Nano VNA - super cheap and an amazing device. The graphs will tell you right away what is going on in many cases.
Also will point out as I did on the Imax 2000 thread - 1.5 is still fine for most people unless you're running large amounts of power or have equipment that can't handle that SWR.
Since lightning killed the old antenna have you checked the rest of your system? Did you get new coax? Did you replace any switch boxes, connectors, etc.?
i got another stick in mindHas anyone tried the Procomm PT99, the 4 piece antenna.
I used the proton pt99 somewhere around 2006 or 07, it tuned and worked but was replaced by an aluminum antenna. I do remember it was only up less than a year and when taken down the fiberglass was extremely dilapidated. But.... it tuned and worked.Has anyone tried the Procomm PT99, the 4 piece antenna.
