A small push button switch under the ptt might work if you can fit it in there. You might be able to hijack the contact that switches the audio wire. Cut the traces for the audio and connect them together, they don't need to be switched. (This is also a fix for a switch that makes a scratchy noise in the audio.) Then use this contact to switch your power. The picture I have in the post above shows which pins on the switch to use.Hi ball the ptt are used I trod a couple different things ground switch using a small relay either dosent work or messes up ghee switching very strange
Woimdering about a small Toggle inside the mic under the ptt switch..
