Does anyone know where you can buy the push to talk switch for the Astatic D104M6B?
even if you manage to get one its going to fail just like the original one .
did you try to clean the switch?
Take apart the switch down to every piece like I did and clean every part by hand than file good contacts on the ptt plates and put in new wire solder it back up u should be fine.
Sent from my DROIDX using Tapatalk 2
I have cleaned the switch using contact cleaner, but it starts to act up again in 2 or 3 months.
Truck stop CB Shop might have a donor mic for some $$$.
yep ,thats how they all are .I have cleaned the switch using contact cleaner, but it starts to act up again in 2 or 3 months.
