homer , do you think your tuning method for the astroplane would work on the astroplane ?
BM, in case you're having a problem remembering, I believe that is what Homer has said. The Avanti Patent also suggested that is what tunes the A/P and I have no reason to disbelieve that even now.
What I told Homer was, when I modeled the A/P I could get the antenna much closer to tune with the proper dimensions that I used, but I could not change the center frequency by making similar changes like he did. I was surprised at the results however, and I've said as much.
Another time that I saw the resonant frequency change with my Top One was when I first tried changing the Top Hat element to a full 1/4 wave element. On considering what I should do to start this project I decided to use the recommended length of 77" inches that is noted in the AstroBeam manual. That turned out wrong and put me in 28 mhz. Here are the Antenna Work Sheets for that project for tuning. Sorry I notice that I posted these in reverse order, but the reports are numbered at the top left side of page.
View attachment AstroPlane tuning for full .25 wave tip..pdf
I would show you the models and try and convince you further BM, but you don't understand a whit about modeling.
If you guys knew how simple getting started in Eznec5 modeling really is, you would all be kicking yourselves. Some have a mental block that they'll never get it, and that is all that is stopping most of you, and some have a block that says modeling is a worthless effort.
BM, I know why you posted the ads, you're famous for doing such. I was just making a point about the credibility problems posting manufacturer's hype that no body believes.
