I will hook up my volt ohm meter just to see how accurate the power supply meter is.
I was gonna suggest the same but see you were on the right track already
Just to let everyone know where I am on this power supply.
I changed the IC regulator, hooked up a Kenwood TS-2000 and keyed up the radio and BAM, the radio shut down.
The amp draw meter slammed all the way over to 40 amps.
Hooked up a voltage meter to the power supply and the voltage varies from 12 to 16 volts just sitting there, with no load.
It slams the meter yet it does not blow fuses is that right? :blink: I can think of a few things that would shut it down even without a load but I just can't figure out the voltage fluctuation issue.It is fast/slow or erratic when it changes? Does it seem to be a smooth and constant change like something is slowly oscillating?
HAHAHAHA I put a new battery in the volt ohm meter and it sits at a constant 13.04 volts![]()
OK time to use a resistive load or some lamps instead of real electronic gear. Even just a few amps draw should be enough to determine what is happening under load. Things like does the voltage go to near zero or does it spike and cause the crowbar cct to trip. Save the gear destruction for long winded QSO's.Stil pegs the meter all the way to the right for amp draw when keying up the TS-2000 and shuts the radio off. No fuses are blown
HAHAHAHA I put a new battery in the volt ohm meter and it sits at a constant 13.04 volts/QUOTE]
yep, those dead batteries in a VOM WILL kill you<gotproof>
I ALWAYS test the batteries in my Simpson,.... EVERY usage
