I've had a AT-5555N for about 4 years or so. After a period of no use, I finally hooked it back up to find it has no modulation or power output on USB/LSB and the receive is muted on USB/LSB also.
AM/FM still work great (lots of modulation and output power). I've tried the "Reset" in the menu with no luck. Also tried a new microphone with no change. Does anybody know folks who can work on these things ? The board is almost identical to the Lincoln II +.....so maybe somebody knows something about it or where to start looking? Most say chunk it in the garbage and get another one..........unfortunately I'm not wired that way. If it were the processor or some other major item maybe......but everything works but SSB. I'm thinking a crystal filter, transistor, diode, or something else.
Anybody have any suggestions either on where to start or who can potentially look at it ??
Thanks - 73's
Thanks - 73's
