They all "can" sound good if you carefully monitor your audio. I have a 870, 850 with DSP100, a 440 and quite a few others. I used to be big with eSSB and back 15 years ago or so I was sorta big on 75 meter AM and enjoyed modifying rice boxes to sound pretty nice on AM but as far as CB is concerned, and this is my opinion, Kenwood's suck on AM.I disagree... a ts 440 or a 450 sound great on am with a d104
Bullshit. Without doing some mod to rework the audio stage components inside, these rigs suck on AM.I disagree... a ts 440 or a 450 sound great on am with a d104
What ever slick.... mine doesn't, with no mods... but everybody has there own interpretation of what sounds goodBullshit. Without doing some mod to rework the audio stage components inside, these rigs suck o
Regarding your main concern, the Q6 is the better solution. I have had both and while the TS-50 wins hands down on SSB TX, it is susceptible to hash and noise. The NB is not as good as the one in the Quad 6. Also the "Q" of the coils is much higher in the Q6, which gives greater selectivity. The Q6 is designed to only cover 3+Mhz while the TS-50 has to cover 30Mhz. IMHO, you will hear legible signals on the Q6 that will be covered up by the higher noise floor of the TS-50.My main concerns are the ability to pull ledgability out of the the very hash heavy environment I am working out of, I have an 11KV step down transformer right next to my property and it seems to drag in and re-radiate all sorts of crap from 20 to about 30 MHz.
Had been considering something with a good DSP as some of those seem to clean a lot of the noise up either that or a Kenwood. My R5000 gets reasonable results in my environment and they do make decent receivers for sure.
The AM side doesn't worry me so much as pretty much I just use SSB and if I want to use AM I can always default to my Galaxy radios, my 95T2 cuts through very well on AM and SSB but the receivers whilst sensitive are somewhat noisy.
