Show me some audio otherwise it doesn't exist.
what is the point if you care or not your name says it all lol.NOT!!!!!!!!!
Nobody has to prove or show you anything.A wise guy once said, "if they're not showing you, they're snowing you"..
Carefully controlled sibilance increases intelligibility at a distance.A real tech can wideband a transmitter and not have annoying sibilance. When the customer puts a crap mic on his "anytone sssixty sssixss sssixty sssixss" all bets are off.
Rpc has told me that my wideband transmitter is inefficient and he's not wrong. However the last video shows the frequency response of his and Mark's radio is beyond 5khz. That's a 10khz wide AM signal. Unfortunately all they seem to emphasize is the annoying sibilance and not the good high end frequencies. Anyone with a clue sees the hyprocisy here.
If you don't have to prove I'm a shill then you can't call me one. I'm not peddling anybody's services. I'm simply showing people what I expect in regards to Performance and hoping that someone steps up to the plate to offer me identical or better performance which has yet to happen.Nobody has to prove or show you anything.
Why don't you and mark go peddle your services elsewhere!
Prove this statement ; (hint) you can't...If... intelligibility.. Notice below 300 Hertz there is nothing since that sound would be lost at a great distance.
More... My radio is better than yoursIf you don't have to prove I'm a shill then you can't call me one. I'm not peddling anybody's services. I'm simply showing people what I expect in regards to Performance and hoping that someone steps up to the plate to offer me identical or better performance which has yet to happen.
Wrong... I'm here to show my expectations hoping you know someone that can meet them.More... My radio is better than yours
So there. ....
Don't you realize you look a immature kid with all your claims and show me this and show me that.
Your only here for one reason, is to drum up business for your God
Haha, 300 cycles really, haha... try 20 cycles.. (and yes, 20 Hz A.F. can be transmitted from a modified CB)
watch?v=ySTNGp17ULI
bla bla, bla... useless techno-jargon..Common sense dictates "wider is less efficient".
Common sense also dictates clipping useless power going to waste at the bottom and shifting it towards the middle, simulating a dsp/speech compressor, increases transmitter efficiency at a distance. Keeping it narrow while maintaining intelligibility keeps the signal out of the mud and maximizes efficiency.
"45 mile cobra 29" is the perfect example of shifting the response, agc, amc, attack timing, while maintaining a higher constant "mean" power making it easier to be heard at a greater distance without increasing output power.
ok ill put a 142gtl on the table see who will bicker about a scratch first lolbla bla, bla... useless techno-jargon..
"less efficient", haha show me the numbers... Does your guy not pride himself on a "wider" signal, so.. what you talkin' 'bout, Willis?
