Automated machines working
I'd like to see that Malaysia plant.
L3Harris was 10 lines. A football field long and as wide as a football field is long.
Have a look in this thread on page 2 about half way down.
The actual factory was large, this was a small assembly room off of the main factory floor.
At that time i had a "acquaintance" that actually worked at the factory in Malaysia.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
