thats great cdx what do you think the chances are of taking a picture of that baby?
I tried but the crappy 3megapixel camera just doesn't capture much more than sky.
Imagine walking out into a big field or park with:
1) a five (10')section, 45' telescoping mast
2) a 1" diameter, 36" long iron stake, one end sharpened & a 6" washer
3) guy wire & dacron line
4) insulators
5) 88' of RG-213
6) an Imax 2000
7) your radio & swr meter
Hammer the stake 18" into the ground leaving 18" of solid stake above ground to keep the bottom of the mast from moving around, plus helping to support the mast upright while guying the bottom 10' section in place with dacron non-metallic line.
Place the tight-fitting 6" washer around the bottom of the iron stake to prevent the mast from sinking into the ground and slide the mast over the stake and guy by 3-4 dacron lines from the top of the mast bottom section 10' up.
Now you have a mast sitting upright and guyed at ten feet alongside of which you may now stand a ladder.
Climb up and install the Imax, attaching the 88' of RG-213 to it and tape well for strain relief.
Add a 23' length of guy wire (including an insulator at the far end) to the top U-bolt on the Imax and let it hang with enough Dacron line from the insulator to reach the ground at a ~45° angle once fully elevated to 45'.
Now elevate the top section of mast ~8'.
Add three 9' guy wires (including insulators at their far ends) to the guy wire ring at the top of the 40' (4th) section of mast. Add enough dacron line to the end insulators to reach the ground for guying at ~40° angle when fully elevated.
Elevate the remaining 3 middle sections of mast 9' each and pull the three 9' guy wires/ dacron out to about a 40° angle and set with stakes or lawn corkscrew type dog leash holders into the ground.
Pull the single 23' guy wire & dacron line out to about a 45° angle and tie off on the ground with another stake.
Drape the 88' of 213 from about the 20' high point on the mast, out and down to the radio about 40' away from the mast.
Now you have my approximate set-up.
Clear as mud?
Thread hijack possibly over.
