i found a file that has a ap drawn in it. someone had sent it to me. might have been you. cant remember. ive played with it a little trying to familiarize myself with the program. can i sent it to you to look at?
Asume it was emailed. It's in format for eznecHow was it sent to you?
That 47" skirt ain't worth nothin. I took off the skirt. Took off the top element. Added a horz element at the bottom of the driven element. It tuned well enough but wasnt too pleased with reception. So put it back to spec except skirt has 2 loops now. Tunes flat for 11 meter and 80 meter bands.
I don't understand exactly what you did, but I'm anxious to hear 2 loops are better than one.
Flat on 80 meters too? Is that a typo?
I would like to see pictures of what you did, so I could model such an idea.
it only acted as a match. sorta. hell i dunno, but it did of course change the analyzer but wasnt all that.What does the horizontal element do?
I was guessing you might tell me it was PVC, and used as a brace against the wind for the radial loop.it only acted as a match. sorta. hell i dunno, but it did of course change the analyzer but wasnt all that.
ium sorry, yes it is a brace. i had used a clip on horz piece to try and use as a matcher. i didnt even think about the pvc. sorryI was guessing you might tell me it was PVC, and used as a brace against the wind for the radial loop.
I doubled the diameter size of the loop from 0.375" to 0.75" on one of my A/P models, and it added 25 ohms of inductance and the resistance went up a bit too. The model had a match that was near perfect, showing less than 0.05 ohm of reactance to start.
