Right, that is pin 3 (not pin 5) so it should have plus volts on it.
Read the voltage on pin 5 to see if you have any bias volts on your tubes, it will be in the 15 to 20 volt negative range (put your plus probe on ground and your black probe on pin 5).
21V on the drives, 0V on the finals, on stand by.
Should I be on operate?
