I really hate these threads and shoulda kept out of it. Everyone knows someone who runs a 100w radio into a 1 pill, into a 2 pill, into a 4 pill that works perfectly. And honestly if you spend your money you can run the dog shit out of it for all I care, but bad advice on a new purchase is just bad advise.
The spec sheet from Toshiba or XForce?
The Toshiba spec sheet says 10w pep max drive and with anything above 4w the linearity starts to drop off badly. Anything above 100-120w pep out and the IMD starts to creep way up above -24dB down. You're talking about 40w pep drive per pill on the 2 pill, and 20w pep drive per pill on the 4 pill. Now these tests are ran at 12.5vdc and most people are running at least 14vdc, but the principle is the same.
If you look at the XForce specs, the 2 pill will key 100w with a 5w input which is 13dB and pretty typical. However, it also says 120w peak drive will produce 400 peak out and that's only 5dB! The 4 pill says 10w carrier in produces 400w out, which again is 13dB and is expected. Peak drive is 240w with 1000w out and we're back down to 6dB.
Carl can say anything he likes, but he didn't make the transistor.
I don't know that Carl ever worked for Dave, but that's here nor there.
SSB doesn't have a carrier.
2-4w peaking 80w is waaay over modulated. So you've got an over modulated radio producing harmonics, and gain compression producing IMD and the whole setup makes way more heat than needed. The difference in 600w and 400w is less than 2dB plus a lot less heat and garbage.
I'm sticking to my guns, an 80w radio into an 8 pill or maybe even a 6 pill would be the better choice in transistor amplifiers. But the best option would be to use tubes that are capable of taking that drive while remaining linear.
I don't see a single thing in this post that I disagree with. Most people don't know the difference between "it works" and "it works like it should" when it comes to running amps. The 11m CB crowd is the ONLY place where 80 watts into a pair of 2879's will work well, stay cool, and not interfere with neighbors. It's also the only radio service where users and their golden screwdriver "techs" know more about the limits of the transistors that they use than the manufacturers of the transistors. Makes me want to give up everything else I have and go back to CB wit a one pill modulator driving a two pill driving a four pill into an 8 pill. Man!! I should be king of the hill with that setup.
