Cable company amplifiers can, and will peg your receive meter.
It got so bad around here that I was being pegged at 10 S units steady 24/7. Power company was doing some upgrades a couple streets over, and it was causing one of the main line cable amplifiers to leak. That's what the lineman said. Anyway, the cable lineman fix would work for a day or two, and it was right back to pegging my receive needle.
Finally, had to call and escalate the problem. This time they fixed it for good after I explained to them. I saw the amplifier on the line after it was fixed, and they took the black weather wrap off of it. No problems since that time.
The cable lineman did do me a favor. He rode down by my house, and found a leak in my house. He showed me on his meter outside. Asked if he could go inside to find the leak. It was just a loose connection to the cable modem, and he tightened it up. We went back outside, and checked the meter, and the leak was gone. It was a small leak, but all the little leaks add up to a lot of noise.
