BBi explains antennas. (put on your high boots)
You need distance and matched radiators to reflect the signal. That's why I hook my RG8 up to railroad tracks by the house, It works like a tuning fork, then used a tuner to adjust for frequency. I get the best results East and West because that's the way the tracks run. "Secret Squirrel keying up on the Baltimore and Ohio. 5 watts swinging cross country. "
should i cut my antenna pole off just below the antenna mount and install a rotating hinge i can control with a rope running through my coax entrance point to go horizintal to vertical? make my ground plains into gp beams?
Reactions: NZ8N and Slowmover
when looking at a sine wave signal we understand that one cycle is equal to the distance from either one crest or trough to the next crest or trough. here's the question. if @ a frequency of 27 mhz this cycle repeats itself 27,000,000 times every second, what is the amount of time required for a single cycle?
if BBI can answer that question then i'll watch his antenna video / "tutorial."
Reactions: Rwb
