The constant reminders not to overdrive is about effective as telling me to drive my car slow when I was 18. Waste of time.
I love watching some of the YouTube builders go: "two hundred bird from this 2 pill, well the watt meter tells me the datasheet lied!" (not literally)dont worry 99.8% of cbers have been over driving transistors in rf amplifiers for 40 years they still have not learnt ....
even running a 2sc2879 @ 100w pep per device will make most real rf engineers roll their eyes and have "S.A.D" spectrum analyser disorder ......a condition only known to affect men that understand IMD
Splatter watts.
You can build anything (in your private shop), selling things (without a great legal disclaimer) can become another story.
A real HF rig for demonstrations, and a good disclaimer (in the video, and at the time of sale or inquiry) would only serve to help things i.m.o.
I agree with you on those sweep tube boxes, and 900 watts carrier , swinging back to 400 under modulation!?!! Wowzer so that's what "pushing it" can be for two 2sc2879's! No wonder people loved to volt these boxes!The most I ever got out of a pair of 2879s was 900 carrier...400 with modulation and a tad over 1kw pep.
Running at 21 volts they drew enough current to make the short 8 gauge power leads get hot. Each poweread was roughly 8 inches long.
It would warm up one of those MFJ 1500 watt dry dummy loads rather quickly. Splatter watts indeed but it would run with those big sweep tube amps for a 10 second key. Those things all belong in a landfill.
I take it some CB'rs never gain the concept of having a box "Loaf Around" @ say 1 Kw, and instead try to superchage a v-6, add nitrous and expect the low end torque numbers of a v-8, as a daily!Volting a comp box like that is like squeezing a couple thousand horsepower out of a V8 for the drag strip, if you're a competitor you know the risks and accept the downsides as a part of competing. It doesn't become a problem until people who don't know any better start using them for daily drivers and expect all the reliability of a more conservative design.
I take most CB'rs never gain the concept of having a box "Loaf Around" @ say 1 Kw.
On a side note the HuaGao Semi (2SC2879) looks promising, if the part had better efficiency (the original) I could see building a big box, but I'm just not into it as they sit.
It's going to need true AB "thermal tracking" biasing and a built-in filter.For the big boys there are better options but I'm still hoping the HuaGao pills work out even if the efficiency is a bit lower. What seems to be missing from the hobby right now is a good quality small amp that will give the little guy a couple hundred clean watts, a decent 2879 replacement would go a long way to getting us there.
The LDMOS stuff and your better tubes bring a lot to the table if you want to go big but for more modest stations they're more work than should be necessary for more power than needed.
Once they put too much drive in and blow it, that $300 for the part alone will make them re-think what they think they know.dont worry 99.8% of cbers have been over driving transistors in rf amplifiers for 40 years they still have not learnt ....
I'm starting to believe four hundred dirty watts will walk on four clean watts all day.
Sure; but does a clean 360 watts walk the dog on 400 dirty watts?I'm starting to believe four hundred dirty watts will walk on four clean watts all day.
