Bearcat 980 ssb,did i mess up trading for 1?
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
4,131
5,890
523
70
I traded my chicom kinda anytone smart cbs and another 2 way radio for a same as new bearcat 980 ssb.
Luckily i discovered how to kill that ugly annoying BEEP.mine must be a newer model as i held down on the anl nb button n killed the BEEP. Got a few things to learn about it yet.
Im tryin it a few days on base then installing it in my pickup.
Wonder what kinda mods are abound for it?
I know it's an 11 meter tradition to modify everything, I used to believe the same, but what are you looking to improve? I can see doing something like disabling an annoying beep. The two 980s that I've heard had good clear audio on AM and SSB.
Reactions: Rwb
Rwb,
Not many, if any, do-it-yourself mods for this radio that I have heard about. There are certainly mods that can be done, depends on how deep your pockets are. A google search should turn up some ideas.
From what I have heard, the 980 is a pretty solid performer. I have heard a few on the air but never operated one.
Good luck.
73's
David
Im just curious.
My 2 anytone smart cbs i did the mod for channel expansion op 1 and op2 then never used the mod.
It might never get modded but seeing what is available
Im just curious.
There is no actual channel mod for this radio that shops or techs can do like older radio's. Not possible. It's a radio that is best left stock, if you try to over tune the wattage you start blowing finals.
Here is a good thread to read, it does talk some about extra channel attempts.
https://www.worldwidedx.com/threads/uniden-bearcat-980.141611/page-4
Th
There are two distinct Bearcat 980 radios.
On the inside.
Not so different on the outside that I can tell
But if you want to diddle the inside, this will matter.
is 1 must be newer,i pushed the anl nb button and held it a short while n beep died.
I hooked it on base.my wife said talking is fine but THAT BEEP MUST GO
  • @ W4KVW:
    Rock Stars ROCKS!
    Looking forward to it Gary!
