The issue with trying to ground an isolated long whip would be the ground wire becoming part of the antenna rather than establishing a ground plane it would most likely try to form a dipole "untuned at best". That could cause ground looping, interference issues with windshield wipers etc. Now It may not, but at this point mounting as low to the ground at the rear of the truck is most likely the best idea.Of like to upload a pic of the truck but apparently I need to host it somewhere...
You could make a ground plane under the fiberglass with a sheet of aluminum. Glue it to the fiberglass with liquid nails and then ground it to the frame of the truck and bed.OK......not a good idea to mount it on a flat fiberglass truck box cap? (Tonneau cover) I plan to ground the ball mount to the frame. Is that not a good idea? Only other option would be to weld an extension to my hitch out towards the end of the bumper and mount it to that. I don't want to mount it to my bumper.
RF does some strange things and is not always easily explained. From what I understand, RF ground is like the zero reference for the RF signal. The RF power uses this reference to work against. In the plastic tool box situation, sure it will work but the coax shield becomes the ground and because it is so small it will radiate power too. Some people improve their vehicle ground plane by bonding the hood, doors and fenders to the main body shell. Then bond the main body and even the exhaust to the frame. If anyone knows of any good links that might explain this a little better please post them. I am not coming up with anything at the moment.Forgive my my lack of knowledge. So when you run a ground wire its not the same as it being mounted to the ground? Good to know. I swear I have seen guys run whips on fiberglass caps that's sort of why I figured it would work. Boy..this RF stuff is strange. And here I was asking about amplifiers and I can't even hook up an antenna. Lol. Can we say walk...no crawl before run? Haha. I'm handy with a soldering iron and a multimeter on old audio equipment...this is much different.
Did you look at the 503 at all? What was your main reasons for the 203 vs the 503? price? size?Even mounting it to the bed rail behind the cab may not work..mine didn't on a 2017 ram. Swr wouldn't drop below 3 and I found the bed is mounted on rubber! I have since went with a Tram triple magnet mount on the roof with a Tram TBC-9 antenna, I have a 980 SSB into a KL203p and besides the swr issue you need to fix you also need to drop the radio deadkey to 1 1/2 - 2 watts or the amp won't last long. You will need a external SWR meter as the internal will be off after dropping the deadkey and the radio test mode will show a fail on TX due to low deadkey. But this is a great radio setup. The one piece of advice I will say is buy the biggest amp you can or your going to want the bigger one soon.
