i WAS GIVEN A 6 MONTH OLD MACA GP IF I TAKE IT DOWN. 1 OF THE GROUND RADIALS ARE BENT DOWN TO ABOUT A 30 DEGREE ANGLE FROM A TREE BRANCH THAT FELL ON IT. WOULD THIS ANTENNA BE DESTROYED BY USING A CONDUIT BENDER TO BEND ALL RADIALS DOWN AT A 30 DEGREE ANGLE? JUST A THOUGHT AS EITHER WAY I WILL HAVE TO REPLACE THE RADIALS BECAUSE IF THE BENT ONE IS PUSHED BACK UP IT WILL SNAP I'M SURE.
