http://hamuniverse.com/wb4yjtdipolepatterns.html
According to the above article, The Best Dipole Setup is somewhere between 20% and 15% wavelength height, where a dipole's impedance crosses 50 Ohms.
For an 11 meter dipole designed for 27.2 mHz with a wavelength of 34.2 feet, this would be a mounting height of around 6 feet, which is pretty darn low.
From the article:
This is not the ideal DX antenna, but it does provide good signal strength at reasonably low angles (6 dB down at 20 degrees elevation angle). It is essentially the same pattern as the .25 wavelength height dipole, but with the benefit of being matched to 50 Ohms. In addition, it provides a very broad NVIS signal lobe. This looks like a good compromise between both modes, and is fairly easy to set up on frequencies above 10 MHz.
Thoughts?
From the article:
Thoughts?
