Best low-end watt/VSWR meter you would suggest
I would not recommend a real low end meter, buy well once or junk many times.
The antenna analyzer is a better tool than just an SWR meter. So much more information available.
I was actually just watching some vids on the MFJ-269C, I honestly don't think I have a real enough need for it to justify that kinda cash....but it'd be nice to play with.
Reactions: Slowmover
Also, its not so much the unit itself, the actual meter movement used has alot to do with the readings you get. You could have the best unit in the world but if you put a cheap meter in it, inaccuracies will happen. The bird meter is a perfect example, its really accurate because the meter they use is high precision. 5% +/-. Cb meters are probably more like 15%.
