ty for the help bout "hp"at the model.. yesterday I did 2 dx no was bad because here I live is alot of thres etc but I have a small problem whit it ss3900 hp when I had the 29ltd my swr was 1.1 good ground etc now when I use it radio I get 2.5 and I cant get it down I check ground and is fine check coax is fine too then I use a external swr meter nd say is 1.2 and when I use the radio swr t say 2.5 wht iswrong?
Sometimes meters on radios arent that good. If you used aen external meter on your set I think I would trust the external meter. Also 2.5 isnt a great SWR reading, but it isnt the worst that it could be. Also check make you calibrated the radios meter correctly. Good Luck!!
