This antenna was designed to work without a ground plane. The companies who want to sell you one are (IMHO) more interested in getting your money than they are in increasing your performance.
Minor tests on a Maco V58 with relation to the distance between the ground plane and the tuning loop has been interesting to say the least. This test has been nothing more than moving the ground plane up and down the base assembly to see how it affects SWR and bandwidth readings. Future tests will include field strength and radiation angles.
What this simple test has taught me is that ground plane orientation does affect the performance of an antenna. You just can't add one or subtract one without changing something.
Tests have been done by KG6AOH with the ground plane kit on the A-99 and I believe the imax 2000 that didn't show much improvement.
If you want to improve the performance of your antenna, get it at least 18' above the ground with higher being better. Also, use a QUALITY coax. I suggest LMR-400 or CableXperts' CXP1318FX.
As always, you will hear from people who will say the addition of the ground plane "significantly" increased their performance. Its hard to argue their findings without witnessing it yourself. Some of these same people will also tell you that the "back door kit" for the Moonraker IV and the PDL-II also improves performance, but as we know, this is not true.
If YOU want to know for sure, buy the ground plane kit and install it on your antenna. Take before and after readings. Keep an open mind! If you find that there is not a performance increase, then you can alwas sell the ground plane kit to someone else who is convinced that this is the way to go; there is one born every minute!
Remember, the BEST money you can ever spend on a radio system is on the antenna and feedline!!!!
