S
Shorty6908
Guest
I have a 97 Toyota T100 pickup, the stock alternator is only 70amps. I have not been able to find a High Amp Denso alternator for this truck for under $300. Could I use a Delco alternator? I can get one of those for a lot cheaper. Are is the only choice to add another battery? I have talked with alternator shops all over the U.S and only found a few that had replacement High Amp Denso alternators. I have also talked with a local rebuild shop, they said the best they could do is 90amp with mine. <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin">
</p>
</p>
