I'm surprised no one mentioned the cancellation and directionality of the ½ wave spaced 'array'.
Maybe you already know this, but placing two antennas ½ wave apart puts them 180° out of phase so when you draw a line running from one to the other antenna you will have cancellation along the projection of that line in both directions, ie: N-S.
Perpendicular to that line, or 'broadside' to the antennas (E-W) you should have gain over only one antenna. This is called a figure-8 or cardioid pattern
If you wanted better omni-directional performance than just a single omni antenna, simply place them 9' apart, not 18'.
The length of the ¼ wave antennas, using ½" EMT should be right about 8' 6" for center-of-band 27.185mHz.
You need to find out the exact velocity factor of the RG-6 from the manufacturer then multiply it by 108" to determine the exact working length of each ½ of the 75ohm phasing harness for ¼ wave (9') spacing. For ½ wave spacing they will both need to be 3/4 wave long to reach the T connector.
I would strongly recommend using a T connector and SO-239 connectors with appropriate down sizing spacers for the RG-6.
If you cut a piece of RG-6 1¼ wave long for one side only you will effectively turn your array sideways and the cancellation will then be broadside to the antennas if they are 18' apart.
If you wanted to set it up for switchable 90° E-W or N-S performance it would require two SPDT relays and a DC relay switching voltage wire to select between the 1¼ and 3/4 wave pieces of RG-6 on one side only.
If you elevate the antennas so they are just high enough to allow a 30° down slope of ¼ wave long elevated radials for each antenna, (maybe 3' antenna base height) you will only require 4 radials each, and should perceive gain over a flat ground mounted system, plus your SWR will be closer to 1:1 as each antenna will be ~52ohms instead of ~37ohms.
- Later you could add 2 more antennas, all 9' or ¼ wave apart in a square configuration, and build a switchable phasing harness for a "Four Square" antenna array and WOW, what a superb selectable directional!
Our 4 square for 80m at the cabin is simply amazing. Provides strong performance with signals which just aren't there on the wire or the Butternut vertical.
Hmm 3 feet is all it would take? I might be able to get that with the saw horses I'm using as bases, I think the stand area would be big enough for support. I AM wanting the figure 8 pattern but eventually might add the 2 other antennas
