Those ferrite chokes should go as close to the antenna's feed point as is possible or practical. They slip over the coax and are 'stacked' (one usually does no goog). How many should you use? As many as you can. That gets sort of expensive, so a coaxial choke (coil of coax) is also usable. How many turns for that coil? Something like 4 - 6 ought'a do it. Something like 6 - 10 inches in diameter depending on the coax used. Just don't wind it too tight.
