So i have a blue"palomar" skipper 2 transistor amp that is very low on output.
Starting on low.med,high to max it goes from 10w to 20,30,40 and max out about 50w.
When testing it SWR was good and it did not get unusually hot, and both transistors got warm.
At first i thought maybe one of the two transistors went bad but my thought is that if one went bad
then they both would not have been warm? Is that correct? I do not see anything that looks burnt
or damaged. As this is the way i got it i do not know the history of what may have happened before.
So I would like to know if anyone can see anything that looks bad they i might have missed and or
what should i be checking to figure out how to fix or troubleshoot to find the problem(s)?
Thank you for your thoughts.
