Anyone build one? The tubes used for Guitar amps are common, cheap, not going anywhere, and typically require similar plate transformers to the old days sweep tube amps.
I got a pair of these may modify an old BlackCat JB-150 (originally 2 8417 tubes) to use these Svetlana SV6550C tubes ($55 matched pair).
SV6550C datasheet and application note, data sheet, circuit, pdf, cross reference, pinout | Datasheet Archive
