You must love seeing a grown man cry.
You know we can't actually see it, but you know.
Your Kung Fu is strong and admired in the proper circles.
He was testing at 80 meters while connected to what I assume was a chain link fence which I'm sure had a direct bonding to earth ground.
Don't most types of dipoles do well at at least one or two wave lengths above earth?
I saw very good (flat) swr on 80 with mine mounted horizontally at 35' or so with a tuner.darn, i missed the actionoh well, perhaps he also asked this on the 'ZED,........... i'll go check there
as far as a chain link fence goes, i have found that they can be a really poor ground, the links may or may not actually really contact each other due to oxidation forming and acting as an insulator.
a low mounted dipole on 80 will work fine as an NVIS antenna, just get a reflecter about 3 to 5% longer under it. but,......... for "most" applications, the higher, the better. YMMV
